Knowledge Base Article
No-Fit in DDR3 Interfaces Due to mem_ck Assignments
Description
This problem affects DDR3 products.
A DDR3 memory interface that compiled successfully in version
11.1 of the Quartus II software may encounter a no-fit in version
12.0 if mem_ck is assigned to a differential pin pair
where p is inside a DQS group and n is
outside the DQS group.
Resolution
The workaround for this issue is as follows:
- Open the file xxx_addr_cmd_pads.v in a text editor.
- Search for the localparam
USE_ADDR_CMD_CPS_FOR_MEM_CKand set its value totrue.
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
