Knowledge Base Article
No expected output when running "aocl env" on emulation aocx file
Description
If you compile your OpenCL™ kernel for Emulation, then you use "aocl env" command to display the emulation aocx file compilation command information, the output would be blank.
Resolution
This is because "aocl env" command no longer supports emulation aocx files from version 19.2 or newer of the Intel® FPGA SDK for OpenCL™.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
