Knowledge Base Article
nios2-gdb-server or nios2-flash-programmer reports "Unable to open input file"
Description
When you run nios2-gdb-server or nios2-flash-programmer on Windows in the Nios II command shell, you might see an error message similar to the following:
/cygdrive/c/Workspace/HelloWorld/HelloWorld.srec: Unable to open input file
This error occurs even though the file (e.g. HelloWorld.srec) actually exists.
This error occurs because nios2-gdb-server and nios2-flash-programmer are no longer dependent on Cygwin. As a result, they do not recognize Cygwin-style paths of the form cygwin/<device letter>/<pathname>.
Resolution
Retype your path as a quoted Windows, mixed, or relative path, as in the following examples:
  • Quoted Windows: "C:\Workspace\HelloWorld\HelloWorld.srec"
  • Mixed: C:/Workspace/HelloWorld/HelloWorld.srec
  • Relative: ../HelloWorld/HelloWorld.srec
Updated 3 months ago
Version 2.0
