Knowledge Base Article
Nios II Application Properties Settings Not Saved
Description
If the active configuration is not selected on the Nios II Application Properties page, you can not save the settings set in the Nios II Application Properties page. The active configuration might be deselected after you edit the settings in Nios II Application Properties.
Resolution
Manually select the active configuration in the Nios II Application Properties page before editing the settings.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
