Knowledge Base Article
NicheStack TCP/IP Stack - Nios II Edition No Longer Supported
Description
You might encounter problems using the NicheStack TCP/IP Stack - Nios II Edition. For example, you might see an error similar to the following:
inet startup error: unable to find any working interfaces
panic: IP
dtrap - needs breakpoint
NicheStack might exhibit other unexpected behavior, different from this example.
Altera no longer supports the NicheStack TCP/IP Stack - Nios II Edition.
The NicheStack TCP/IP Stack is a TCP/IP protocol stack created by InterNiche Technologies, Inc. The version provided by Altera is supplied as example code only and is supplied without any product support.
Resolution
If you require a supported TCP/IP stack you should license a product from a third party software vendor.You can license a newer version of the NicheStack TCP/IP Stack and other protocol stacks directly from InterNiche Technologies, Inc. (www.interniche.com).
Updated 3 months ago
Version 2.0
