Knowledge Base Article
NativeLink Simulation in UniPHY External Memory Interfaces fail for VHDL Output
Description
In version 10.0 of the Quartus II software, when a user specifies VHDL output for the DDR2 and DDR3 SDRAM Controller with UniPHY, the QDR II and QDR II SRAM Controller with UniPHY, or the RLDRAM II Controller with UniPHY, and attempts to simulate using NativeLink, NativeLink fails and reports that it cannot find the file <design_name>.vho in the top-level directory.
Resolution
The workaround for this issue is to edit the <design_name>.vhd file and remove the line similar to the following:
-- IPFS_FILES : <design_name>.vho.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
