Knowledge Base Article
Missing .dat File Error Message: “Failed to open VHDL file”
Description
When you simulate a Qsys hardware design in VHDL that contains the JTAG UART core, and you run the simulation using the ld_debug command, you might see the following error message:
# ** Error: (vsim-7) Failed to open VHDL file "system_tb_system_inst_jtag_input_stream.dat" in r mode.
You can safely ignore this error, because it does not affect the stdout output of the JTAG UART.
This error message does not appear when simulating a hardware design in the Verilog HDL.
Resolution
Run the simulation using the ld command, and the error is not displayed.
Alternatively, ignore the error message.
Updated 3 months ago
Version 3.0
