Knowledge Base Article
Mentor Graphics AXI Verification IP AE in the Quartus II 13.1 release does not support QuestaSim 10.2b for windows
Description
Mentor Graphics® AXI3™/AXI4™ Verification IP Suite Altera® Edition that is released with Quartus® II 13.1 will not work with QuestaSim® 10.2b for windows.
Resolution
To work around this problem, download and install patch 1.02 from the links below. You must install the Quartus II software version 13.1 before installing this patch.
Note once you install this patch, the -mvchome path changes depending on the the Modelsim/QuestaSim version.
For Questa/Modelsim on Linux, or Questa/Modelsim 10.2 on windows use:
vsim -mvchome /../ip/altera/mentor_vip_ae/common -c -do example.do
For Questa/Modelsim 10.1 and Modelsim 10.1 Altera Edition on windows use:
vsim -mvchome /../ip/altera/mentor_vip_ae/common_windows_10_1 -c -do example.do
Updated 4 months ago
Version 4.0
