Knowledge Base Article
memcpy() Optimization Misalignment
Description
When optimization is turned on (-O1 or higher), if you use memcpy() and the source pointer is aligned to a 32-bit boundary, the compiler implements memcpy() with word-oriented instructions as part of the optimization process. This optimization technique causes unexpected results in your software if memcpy() is used on a misaligned address.
Resolution
Take steps to ensure that an optimized implementation of memcpy() is called only with aligned data pointers.
Updated 11 months ago
Version 3.0
