Knowledge Base Article
MegaCore Library Does Not Appear in 32-bit Versions of DSP Builder
Description
In Simulink, under Libraries, when you expand DSP Builder Standard blockset, the MegaCore Functions library does not appear. This problem only affects 32-bit version of DSP Builder.
Resolution
To work around this problem:
- Start DSP Builder. Click on Start, point to All Programs, click Altera <version>, click DSP Builder, and click Start in MATLAB version XX (32-bit).
- In MATLAB, type the following command in the Command Window:
alt_dspbuilder_setup_megacore - In Simulink, under Libraries, expand DSP Builder Standard blockset, the MegaCore Functions library appears.
This problem is fixed in DSP Builder v13.1.
Updated 2 months ago
