Knowledge Base Article
Linker Errors with Dual-Port Memories
Description
If your instruction master and data master ports are connected to the same dual-port memory and the ports have different addresses, your code fails to run or you experience a linker error. The Nios II IDE does not warn you of the addressing violation.
Resolution
Assign the same address to both ports of the dual-port memory.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
