Knowledge Base Article
Link-Up Issues with DisplayPort IP Core 15.0 Designs
Description
The DisplayPort designs (av_sk_4k and sv) in version 15.0 of the DisplayPort IP core has link-up issues on the TX core. This problem is caused by the error in the TX transceiver reconfiguration module link rate connection. The TX transceiver reconfiguration module link rate is connected to the wrong link rate indicator causing the TX transceiver to reconfigure the wrong data rate.
Resolution
To correct the connection error, edit the following lines in the top wrapper files, top.v for av_sk_4k and sv_dp_demo.v for sv:
<Original> bitec_reconfig_alt_av/sv bitec_reconfig_alt_av/sv_i( .tx_link_rate (dp_rx_reconfig_link_rate_8bits), )
<Change to> bitec_reconfig_alt_av/sv bitec_reconfig_alt_av/sv_i( .tx_link_rate (dp_tx_reconfig_link_rate_8bits), )
This issue is fixed in version 15.0 Update 2 of the DisplayPort IP core.
Updated 2 months ago
Version 2.0
