Knowledge Base Article
Latch Blocks Give Synthesis Errors
Description
Latch blocks give synthesis errors when you set the Type to uint8 (Boolean). This issue affects all designs that use latch blocks. The design gives synthesis errors.
Resolution
To work around the issue, set the Type as ufix(1). This issue is fixed in the DSP Builder advanced blockset v12.0 SP1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
