Knowledge Base Article
Is there a known issue with the size of a file generated using the sof2flash utility in Quartus II software versions 12.1, 12.1 SP1, and 12.0?
Description
Yes, there is a known issue with the size of a file generated using the sof2flash utility in the Quartus® II software versions 12.1, 12.1 SP1, and 12.0. In these versions of the Quartus II software, the generated file is 1 byte shorter than expected which may lead to configuration failure.Resolution
This issue is fixed in the Quartus II software version 13.0.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
