Knowledge Base Article
IP Compiler for PCI Express Root Port Bus Functional Model (BFM) and Endpoint Design Example Not Available
Description
The IP Compiler for PCI Express root port BFM and endpoint design example are not available for simulation in version 11.0 SP1 of the Quartus II software. If you begin simulation, the following message displays: “BFM model not available.”
This issue affects the root port and endpoint design examples described in the “Testbench and Design Example”, “SOPC Builder Design Example”, and “Qsys Design Example” chapters of the IP Compiler for PCI Express User Guide.
Resolution
The workaround is use a third-party BFM for simulation.
This issue is fixed in version 12.0 SP1 of the IP Compiler for PCI Express.
Updated 11 months ago
Version 3.0
