Knowledge Base Article
IP Catalog lists three IP cores starting with the name Altera Voltage Sensor. Which one do I use?
Description
In IP Catalog, you see three IP cores with names starting with Altera Voltage Sensor. Only use the IP with name Altera Voltage Sensor in your design. Do not use the other two, which are incorrectly listed sub-components in your design.
Resolution
This problem is scheduled to be fixed in a future version of the Quartus II software
Updated 3 months ago
