Knowledge Base Article
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/quartus_interface/qi_common/vpr_qi_external_api_interface.cpp, Line: 6413
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 23.1 and earlier, you might see this internal error during the Fitter stage when running Rapid Recompile from the Signal Tap Logic Analyzer.
Resolution
To work around the problem, run a full compilation instead of Rapid Recompile.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
