Knowledge Base Article
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_re_network_routing_constraints.cpp, Line: 654
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.1, you may see this internal error during the fitter stage of compilation.
Resolution
To work around this problem, remove or disable all VIRTUAL_PIN assignments which refer to signals *_ptp*.
This problem has been fixed beginning with version 19.3 of the Intel® Quartus® Prime Pro Edition software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
