Knowledge Base Article
Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_translator_av_hmcphyint.cpp, Line: 2939
Description
Due to a problem in the Quartus® II software version 12.0 SP2, you may see this error during fitting if your design includes a Hard Memory Controller and it targets an Arria® V device.
Resolution
To work around this problem, download and install patch 2.18 from the links below. You must install the Quartus II software version 12.0 SP2 before installing this patch.
- Download the version 12.0 SP2 patch 2.18 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.18 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.18 (.txt)
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
