Knowledge Base Article
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_micro_tnodes_dag.cpp, Line: 626
Description
This error may be seen in the Quartus® II software version(s) 12.0sp2 and earlier when running the EDA Netlist Writer to create IBIS Models for designs targeting the Arria® V family.
This error is triggered if the port list for the top level design file contains differential pin pairs and the negative pin(n) is listed before the positive pin (p) of the same pair.
Resolution
To work around this problem in the Quartus II Software version 12.0SP2 and earlier, ensure your top level design file lists the positive (p) pin of differential pairs before the negative (n) complement pin.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
