Knowledge Base Article
Internal Error: Sub-system: SDR, File: /quartus/sld/sdr/sdr_tx_signal_nodes.cpp, Line: 186
Description
Due to a problem in the Quartus® II software version 12.0 and later, you may see this internal error when dragging the nodes from the Technology Map Viewer to the SignalTap™ II Logic Analyzer.
Resolution
To work around this problem, perform one of the following two options:
- In the Technology Map Viewer, right-click on the desired nodes and select Add Node to SignalTap II Logic Analyzer option and then select a new or existing SignalTap II (.stp) file.
- Add nodes within the SignalTap II Logic Analyzer by double-clicking on any empty space in the node list pane and opening the Node Finder.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
