Knowledge Base Article
Internal Error: Sub-system: SAD, File: /quartus/sld/sad/sad_advanced_trigger_data.cpp, Line: 2357
Description
Due to a problem in the Quartus® Prime Software, you may see this internal error when you save a Signal Tap file. This error occurs when all of the tapped nodes have the Trigger Enable unchecked and the Trigger Condition is set to Basic OR.
Resolution
To work around this problem, enable the Trigger Enable on at least one node and set the Trigger Condition to Don't Care.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
