Knowledge Base Article
Internal Error: Sub-system: RDB, File: /quartus/db/rdb/rdb_utility.cpp, Line: 396
Description
Problem Details
After compiling the design and running TimeQuest timing analyzer, clicking on ‘report top failing paths’ , changing the model in ‘set operating conditions’ and reporting ‘top failing paths’ again causes TimeQuest to crash with the following error-
Existing object with the specified name is not a folder.
Stack Trace:
0x98455: rdb_get_folder_by_name(RDB_FOLDER_OBJECT*, std::string const&, bool) 0x7d (db_rdb)
Resolution
This problem is fixed beginning with the Quartus® Prime software version 16.1 Update 1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
