Knowledge Base Article
Internal Error: Sub-system: QTK, File: /quartus/db/qtk/qtk_qic_export_writer.cpp, Line: 1332
Description
Due to a problem in the Quartus® Prime Standard Edition software version 17.0 Update 2 and earlier, you may see this internal error when exporting a design partition.
Resolution
To work around this problem, disable the "Flatten child partitions" option in the "Export Design Partition" dialog box.
Alternatively, if you are using command line mode then add the "-dont_flatten" argument to the export_partition command.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
