Knowledge Base Article
Internal Error: Sub-system: QHD, File: /quartus/comp/qhd/qhd_database_utils_splitter.cpp, Line: 806
Description
Due to a problem in the Quartus® Prime Pro Edition software version 18.1, you may see this internal error when you have illegal global clock assignments in your Quartus Settings File (.qsf).
Resolution
To work around this problem, remove the global clock assignments.
Updated 11 months ago
Version 3.0
