Knowledge Base Article
Internal Error: Sub-system: PDPW, File: /quartus/sys/pdpw/pdpw_frame_wnd.cpp, Line: 440
Description
Due to a problem in the Quartus® Prime Pro Edition Sofware version 17.1 Update 2, you may see this internal error when opening the Interface Planner.
Resolution
To work around this problem delete all the files in the Unix's /tmp directory. For Windows, reboot the PC.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 19.1
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
