Knowledge Base Article
Internal Error: Sub-system: OPT, File: /quartus/synth/opt/opt_dsp_wys.cpp, Line: 1688
Description
Due to a problem in the Quartus® II software version 13.1 Update 4 and earlier, you may see this error when compiling a FIR Compiler II design.
Resolution
To work around this problem, download and install patch 4.47 from the links below. You must install the Quartus II software version 13.1 Update 4 before installing this patch.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 4 months ago
Version 4.0
