Knowledge Base Article
Internal Error: Sub-system: OCT, File: /quartus/periph/oct/oct_gen6_read_assignments.cpp, Line: 2587
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.2 and earlier, you may see this internal error when the pins of oct_rzqpin and ddr_pll_clk for the EMIF core are set as Virtual Pin.
Resolution
To work around this problem, turn off the Virtual Pin setting for the two pins.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
