Knowledge Base Article
Internal Error: Sub-system: HSSI, File: /quartus/periph/hssi/hssi_reconfig_op.cpp, Line: 5331
Description
You may encounter the above internal error in Quartus II Software versions 12.1 and earlier if you implement the following Arria V GX design transceiver designs
  • Bonded TX only channel driven by CMU PLL through xN clocking
or
  • Bonded channel (TX only or duplex) driven by fPLL through xN clocking
This is a known bug in the Quartus II Software
Resolution
To fix this problem, install Quartus II software version 12.1 and software patch 0.dp3.
Updated 11 months ago
Version 3.0
