Knowledge Base Article
Internal Error: Sub-system: HDB, File: /quartus/db/hdb/hdb_syn_iname.cpp, Line: 999
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 17.1 Update 1, you may see this internal error when you compile your project which contains blocks with "~" in the block names.
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 18.0 Update 1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
