Knowledge Base Article
Internal Error: Sub-system: HDB, File: /quartus/db/hdb/hdb_syn_iname.cpp, Line: 472
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 18.0 update 1 and earlier, you may see this error at Analysis and Synthesis stage when you use a special character '~' for the pin name.
Resolution
To work around this problem, remove the special character '~' in the pin name.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 18.1
Updated 1 month ago
