Knowledge Base Article
Internal Error: Sub-system: HDB, File: /quartus/db/hdb//hdb_asgn.cpp, Line: 1571
Description
Due to a problem in the Quartus® II software version 13.1 and later, you may see this Internal Error when compiling a design with a Quartus II Exported Partion File (.qxp)
Resolution
To work around this problem, download and install patch 3.03 from the links below. You must install the Quartus II software version 13.1 Update 3 before installing this patch.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 4 months ago
Version 4.0
