Knowledge Base Article
Internal Error: Sub-system: FPP, File: /quartus/fitter/fpp/fpp_cell.cpp, Line: 703
Description
Due to a problem in the Quartus® II software versions 12.0, you may see this error message if you change a pin location while using incremental compilation.Resolution
To work around this error, compile the design with all partitions set to Source.
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
