Knowledge Base Article
Internal Error: Sub-system: FIOMGR, File: /quartus/fitter/fiomgr/fiomgr_io_power_region.cpp, Line: 2351
Description
Due to a problem in the Quartus® II software version 13.0 SP1 and later, you may see this error if your design contains the following line in the Quartus II Settings File (.qsf)
set_global_assignment -name FORCE_CONFIGURATION_VCCIO ON
Resolution
To work around this problem, comment out the line in the .qsf:
This problem is scheduled to be fixed in a future release of the Quartus II Software.
Updated 3 months ago
