Knowledge Base Article
Internal Error: Sub-system: DMIG, File: /quartus/ddb/dmig/dmig_checker.cpp, Line: 307
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 17.0 Update 1 and earlier, you may find the Internal Error above when you do the migration device for Cyclone® 10 devices.
Resolution
To work around this problem, for Quartus® Prime Pro Edition Software version 17.0 Update 1, download and install patch 1.02 from the links below. You must install the Quartus® Prime Software version 17.0 Update 1 before installing this patch.
This problem is fixed starting with the Quartus® Prime Pro Edition Software version 17.1.
Updated 8 months ago
Version 3.0
