Knowledge Base Article
Internal Error: Sub-system: DBMUI, File: /quartus/db/dbmui/dbmui_manager.cpp, Line: 1179
Description
Due to a problem in the Quartus® II software version 12.0 SP2 or earlier, you may see this internal error when compiling your design after clicking Update Symbol or Block in the Block Editor.
Resolution
A patch is available to fix this problem in the Quartus II software version 12.0 SP2. Download and install patch 2.16 from the appropriate link below:
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 4 months ago
Version 4.0
