Knowledge Base Article
Internal Error: Sub-system: BITASM, File: /quartus/pgm/bitasm/bitasm_update_main_descriptor.cpp, Line: 180. OPN Specification U is not mapped to SKUID
Description
Due to a problem in Quartus® Prime Pro Edition Software version 26.1, you may see this internal error when trying to provision a root key (.qky) or AES root key compact certificate (.ccert) into an Agilex® 3 FPGA device.
Resolution
To work around this problem, generate a helper image (.rbf) for your specific Agilex® 3 FPGA variant and configure the FPGA with the generated helper image prior to provisioning the .qky or .ccert file.
For example :
quartus_pfg --helper_image -o helper_device=A3CY100BM16A -o subtype=PROVISION provision_helper.rbf
quartus_pgm -c<n> -mjtag -o "p;provision_helper.rbf" --force
quartus_pgm -c<n> -mjtag -o "p;root.qky"
This problem will be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 4 months ago
Version 3.0No CommentsBe the first to comment
