Knowledge Base Article
Internal Error: Sub-system: ATCL, File: /quartus/ccl/atcl/atcl_root.cpp, Line: 987
Description
Due to a problem in the Intel® Quartus® Prime Pro edition software version 19.2 for Windows*, you may see this internal error message when the fitter stage is being executed.
The internal error description will include a DLL module that could not be found by Windows* operating system. e.g.
ERROR: Can't load library: c:\\intelfpga_pro\19.2\quartus\bin64\fitter_fdrgn.dll. The operating system reports the following error: The specified module could not be found.
Resolution
To work around this problem, install the Visual C Redistributable Packages for Visual Studio 2013 from the following link.
Updated 11 months ago
Version 3.0
