Knowledge Base Article
Internal Error: Sub-system: ATCL, File: /quartus/ccl/atcl/atcl_args.cpp, Line: 1080
Description
Due to a problem in the Quartus® II software version 12.1 SP1 and earlier, you may see this error when running the following commands from the Quartus II Tcl Console for the PCI reference design:
source pci_constraints_for_pci.tcl
add_pci_constraints -speed 33Resolution
To work around this problem, run quartus_sh -s to run the Quartus II shell in interactive and use it to open the project and run the commands:
project_open top_pci32.qpf
source pci_constraints_for_t32.tcl
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
