Knowledge Base Article
Internal Error: Sub-system: ASMGX, File: /quartus/comp/asmgx/asmgx_pm_pma3.cpp, Line: 3077
Description
Due to a problem in the Quartus® II software version 12.1 and later, you may see this internal error during the Assembler when you use a reserve pin assignmnet to a refclk pin and the clock is not used in the design.Resolution
To work around this issue, remove the assignments to this clock pin.
This problem is scheduled to be resolved in a future release of the Quartus II software.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
