Knowledge Base Article
Internal Error: Sub-system: ASMDD, File: /quartus/comp/asmdd/asmdd_stratixv_hd_pcs10g_rx_chnl_uint_auto_generated_asm.cpp, Line: 219
Description
You may see the above error in the Arria® V GZ device if you are using Native PHY with 10G PCS and change the TX and RX FIFO full and empty threshold values in Quartus® Prime version 15.1. This is because the TX and RX FIFO full and empty threshold values are fixed and should not be changed in design.
Resolution
This is a known problem in Quartus Prime version 15.1. To work around this, you can keep the threshold values to their default.  This problem will be fixed in a future version of the Quartus Prime software.
Updated 1 month ago
Version 3.0
