Knowledge Base Article
Internal Error: Sub-system: ASMCC, File: /quartus/comp/asmcc/asmcc_bitfield.cpp, Line: 989
Description
Due to a problem in the Quartus II software version 13.0 SP1 and earlier, you may see this error during the Assembler for designs using the right-side PCIe HIP.
Resolution
A patch is available to fix this problem for the Quartus II software versions 13.0 and 13.0 SP1. Download and install the appropriate from the links below.
This problem is scheduld to be fixed in a future release of the Quartus II software.
Updated 3 months ago
Version 5.0
