Knowledge Base Article
Intermittent Data Corruption
Description
This errata affects the Triple-Speed Ethernet MegaCore function.
When you turn off the Enable SGMII bridge logic parameter in designs that include a GXB transceiver and target all V series device, you may observe intermittent data corruption.The issue affects designs that contain GXB transceivers and target V series devices.
Resolution
Turn on the Enable SGMII bridge logic parameter in the designs.
This issue is fixed in version 12.0 of the Triple-Speed Ethernet MegaCore function.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
