Knowledge Base Article
Inefficient Memory Transactions For Quarter-rate Designs
Description
This problem affects DDR3 products.
The HPC II memory controller might be unable to perform seamless back-to-back sequential read or write transactions in quarter-rate designs.
Resolution
The workaround for this issue is to modify the alt_mem_ddrx_controller.v file as described below.
Open the alt_mem_ddrx_controller.v file in an editor and locate the following lines:
localparam CFG_MAX_PENDING_RD_CMD = 16; localparam CFG_MAX_PENDING_WR_CMD = 8;
In the above lines, change 16 to 32 and change 8 to 16.
This issue will be fixed in a future release.
Updated 11 months ago
Version 3.0
