Knowledge Base Article
Incorrect Register Value After Tx/Rx Reset
Description
Some of the Low Latency 10GbE MAC registers will have incorrect value after being reset with tx_rst_n or rx_rst_n.. This issue affects the following registers:
  • 0x0FE-0x0FF: Tx Underflow Truncated Data Frame Count
  • 0x0FC-0x0FD: Rx Overflow Truncated Packet Count
  • 0x0FE-0x0FF: Rx Overflow Dropped Packet Count
  • 0x140-0x17E: Tx Statistics (only affects register-based statistics)
  • 0x1C0-0x1FE: Rx Statistics (only affects register-based statistics)
  • 0x240: ECC Error Status
Resolution
To overcome this issue, write or read the following addresses to clear the registers as shown in table below.
Registers
Workaround
After tx_rst_n, read at address 0x03E to clear the register.
After rx_rst_n, read at address 0x0FC to clear the register.
After rx_rst_n, read at address 0x0FE to clear the register.
After tx_rst_n, write 0x1 to address 0x140 to clear the statistics counter.
After rx_rst_n, write 0x1 to address 0x1C0 to clear the statistics counter.
After tx_rst_n or rx_rst_n, read at address 0x240 to clear the registers.
This issue will be fixed in a future version of the Low Latency 10GbE MAC MegaCore function.
Updated 2 months ago
Version 2.0
