Knowledge Base Article
Incorrect Multiple Port Address Width
Description
For DDR2 and DDR3 interfaces targeting Arria V or Cyclone V devices with the Enable Hard External Memory Interface parameter turned on and multiple port front end widths as shown in the following table, a correction factor is needed.
This issue may cause your design to fail in simulation. This issue affects DDR2 and DDR3 interfaces targeting the hard memory interface resources on Arria V or Cyclone V devices. This issue will be fixed in a future version of the DDR2 and DDR3 SDRAM Controller with UniPHY.
Total Memory Interface Width
| Multi-Port Front-End Width | Correction Required |
8
32
-1
8
64
-2
8
128
-3
8
256
-4
16
64
-1
16
128
-2
16
256
-3
32
32
1
32
128
-1
32
256
-2
40
160
-1
40
320
-2
Resolution
The workaround for this issue is as follows:
- In a text editor, open the file
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv. - In
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv, add the following lines after// New parameters for HMC:
parameter AVL_ADDR_WIDTH_PORT_0 = AVL_ADDR_WIDTH <\'Correction needed\'
- value> ;
parameter AVL_ADDR_WIDTH_PORT_1 = AVL_ADDR_WIDTH <\'Correction needed\'
- value> ;
parameter AVL_ADDR_WIDTH_PORT_2 = AVL_ADDR_WIDTH <\'Correction needed\'
- value> ;
parameter AVL_ADDR_WIDTH_PORT_3 = AVL_ADDR_WIDTH <\'Correction needed\'
- value> ;
parameter AVL_ADDR_WIDTH_PORT_4 = AVL_ADDR_WIDTH <\'Correction needed\'
- value> ;
parameter AVL_ADDR_WIDTH_PORT_5 = AVL_ADDR_WIDTH <\'Correction needed\'
- value> ;
- In
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv, replaceAVL_ADDR_WIDTHwith the respectiveAVL_ADDR_WIDTH_PORT_#, for example:
Replace input [AVL_ADDR_WIDTH - 1 : 0] avl_addr_0;
with
input [AVL_ADDR_WIDTH_PORT_0 - 1 : 0] avl_addr_0;
- In
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv, comment out the lines fromassign i_avst_cmd_data_0 = i_avst_cmd_data_g[0];
until
assign avl_size_g[5] = avl_size_5;
- In
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv, add the following lines immediately after the section above:
assign i_avst_cmd_data_0 = {{42-AVL_SIZE_WIDTH-34{1\'b0}},avl_size_0,{34-AVL_ADDR_WIDTH_PORT_0-2{1\'b0}},avl_addr_0,avl_write_req_0,avl_read_req_0};
assign i_avst_cmd_data_1 = {{42-AVL_SIZE_WIDTH-34{1\'b0}},avl_size_1,{34-AVL_ADDR_WIDTH_PORT_1-2{1\'b0}},avl_addr_1,avl_write_req_1,avl_read_req_1};
assign i_avst_cmd_data_2 = {{42-AVL_SIZE_WIDTH-34{1\'b0}},avl_size_2,{34-AVL_ADDR_WIDTH_PORT_2-2{1\'b0}},avl_addr_2,avl_write_req_2,avl_read_req_2};
assign i_avst_cmd_data_3 = {{42-AVL_SIZE_WIDTH-34{1\'b0}},avl_size_3,{34-AVL_ADDR_WIDTH_PORT_3-2{1\'b0}},avl_addr_3,avl_write_req_3,avl_read_req_3};
assign i_avst_cmd_data_4 = {{42-AVL_SIZE_WIDTH-34{1\'b0}},avl_size_4,{34-AVL_ADDR_WIDTH_PORT_4-2{1\'b0}},avl_addr_4,avl_write_req_4,avl_read_req_4};
assign i_avst_cmd_data_5 = {{42-AVL_SIZE_WIDTH-34{1\'b0}},avl_size_5,{34-AVL_ADDR_WIDTH_PORT_5-2{1\'b0}},avl_addr_5,avl_write_req_5,avl_read_req_5};
- In
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv, comment out the following line:
i_avst_cmd_data_g[port_i] = {avl_size_g[port_i],{34-AVL_ADDR_WIDTH-2{1\'b0}},avl_addr_g[port_i],avl_write_req_g[port_i],avl_read_req_g[port_i]};
- In all wrappers that instantiate the
altera_mem_if_hard_memory_controller_top(arriav/cyclonev).sv, update the bus width for eachavl_addr_<port>, as follows:
Replace input wire [21:0] avl_addr_0, // .address
with
input wire [21<\'Correction needed\' value>:0] avl_addr_0,
// .addressUpdated 11 months ago
Version 3.0No CommentsBe the first to comment
