Knowledge Base Article
Incorrect Connections Shown in SOPC Builder Illustration in PCI Express Compiler User Guide
Description
Figure 16-3, Port Connections in the
PCI Express Compiler User Guide is missing a connection from the
dma_0 read_master to the onchip_memory2_0 s1.
In addition, it shows an incorrect connection from the pcie_compiler_0 bar2_Non_Prefetchable to onchip_memory2_0 s1.
This is a documentation error only. The following figure illustrates the correct connections.
Resolution
No workaround is required. Make the connections described in Table 16-6, SOPC Builder Connections, in the IP Compiler for PCI Express User Guide
This issue is fixed in version 11.0 of the IP Compiler for PCI Express User Guide.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
