Knowledge Base Article
Implementation of ALTGX megafunction in Deterministic Latency mode might generate a warning message in the Quartus II software for Cyclone IV GX
Description
If you implement an ALTGX megafunction in Deterministic Latency mode, the Quartus II software might generate messages similar to the following:Warning (10541): VHDL Signal Declaration warning at c4gx_test.vhd(62): used implicit default value for signal "pll_reconfig_done" because signal was never assigned a value or an explicit default value. Use of implicit default value may introduce unintended design optimizations.Warning (10036): Verilog HDL or VHDL warning at c4gx_test.vhd(142): object "wire_receive_pcs0_signaldetect" assigned a value but never read
Resolution
You may safely ignore these messages.
Updated 11 months ago
Version 3.0
