Knowledge Base Article
How to run Arria® 10 SoCFPGA-HardwareLib-Ethernet-A10-ARMCC example in SoC FPGA Embedded Development Suite (SoC EDS) Professional Edition Software Version 2020.1?
Description
Due to a problem in running directly the Arria® 10 SoCFPGA-HardwareLib-Ethernet-A10-ARMCC example in SoC FPGA Embedded Development Suite (SoC EDS) Professional Edition Software Version 2020.1. The application hung after printing the below lines in the App console, and the Arria® 10 SX SoC Development Kit is not getting any IP address from the Server.
Resolution
To workaround this problem, please find attached document SoCFPGA-HardwareLib-Ethernet-A10-ARMCC.pdf to follow the step by step procedure to run the Arria® 10 SoCFPGA-HardwareLib-Ethernet-A10-ARMCC example.
Updated 3 months ago
Version 2.0
