Knowledge Base Article
How To Performed Sector Erase or Sub Sector Erase in ASMI Parallel II IP?
Description
There is an issue on ASMI Parallel II IP User Guide on performing "Sector Erase", "Subsector Erase" and "Sector Protect"
Resolution
Below is the updated table 3 of the Altera ASMI Parallel II IP User Guide
Offset | Register Name | R/W | Field Name | Bit | Width | Description |
4 | SECTOR_ERASE | W | Flashaddress | 31:0 | 32 | Erased the sector location based on that specific flash address |
5 | SUBSECTOR_ERASE | W | Flash address | 31:0 | 32 | Erased the subsector location based on that specific flash address |
21 | SECTOR_PROTECT | W | Sector protect value | 6:2 | 5 | Value to write to status register to protect a sector. |
Updated 2 months ago
